style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
<jdiverjp> wrote in messageHi
href="news:6057121@discussion.autodesk.com">news:6057121@discussion.autodesk.com...
All Last night I upgraded from ADMS 2008 to ADMS 2009, it seem to work but now
the clients get this error: Vault Explorer 2009 could not find the Data
Management Services on volt I read more than a few posts here, and I found
that if I restarted the WolrdWide Publishing Service, the AutoDeskDM website
would become available again and I would be able to access:
http://localhost/AutodeskDM/Services/SecurityService.asmx and
http://localhost/AutodeskDM/Services/JobService.asmx However, after a few
minutes it would become unavailable once again... No error on the browser it
would simply hang on the requested page. So I check the iis server logs and
found that the DefaultApplication Pool was abandoning connections, so I
installed and ran the Debug Diagnostics Tool and found the following below.
The problem seem to be the DWFFilter but I don't know how to fix it, any
ideas. Detected a serious critical section related problem in
w3wp.exe__DefaultAppPool__PID__3476__Date__10_23_2008__Time_11_46_21AM__988__IIS
Hang Dump.dmp Lock at DWFFilter!DllGetClassObject+22d19c owned by thread 28 is
Deadlocked with lock at ntdll!LdrpLoaderLock owned by thread 30 Impact
analysis 2.78% of threads blocked (Threads 30) The following functions are
involved in the root cause
DWFFilter!DllGetClassObject+2a56
href="news:6057895@discussion.autodesk.com">news:6057895@discussion.autodesk.com...
Dain I tried the patch, it imporved a little but after it few minutes the same
thing happend. I ran the Server Diagnostics tool, and the result is Login
failed for user sa. I changed logon information for the SQL Service and no
matter what user I used it gives the same error, Login failed for user "sa"
Any ideas? Thanks Juan
