Vault General Discussion
Valued Contributor
jacoj
Message 1 of 5 (188 Views)
vault error value canot be null
188 Views, 4 Replies
01-07-2014 11:38 PM
please help !!! cant access vault file, only folders is vissible, if I change the view settings, you can see imnage, and try to open I get the attached error. 2013 PDSS trail ran out, and we installed 2014 PDSS trial while we waited for 2013 LIC . we are now back on 2013 PDSS installed and licenced, but, vault is giveing this error, any idea how to fix this, without formatting, its a huge issue to get an older version LIC
This is due to .Net 4.5 which is installed from 2014 release. We have fixed this issue in Vault 2013 SP1. You can download and install it from the following link.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21017345&linkID=9261341
If possible please go ahead and install the latest Update 2 for SP1 from this
http://usa.autodesk.com/adsk/servlet/ps/dl/index?linkID=9261341&id=2334435&siteID=123112#section2
Hope that helps.
No. You do not need to remove .Net 4.5. Installing SP1 will fix the issue.
Employee
Senthil-Autodesk
Message 2 of 5 (181 Views)
Re: vault error value canot be null
01-08-2014 12:47 AM in reply to: jacoj
Hope that helps.
Senthil Kumar
Vault QA Team
Be sure to check out the Vault Help!
Valued Contributor
jacoj
Message 3 of 5 (178 Views)
01-08-2014 12:55 AM in reply to: Senthil-Autodesk
Thank you
Will do this,
But do I need to manually remove the .NET 4.5?
Kind Regards
Jaco Jansen van Rensburg
Drawing Office Administrator
ELB ENGINEERING SERVICES
ELB ENGINEERING SERVICES AFRICA
Direct: +27 (0) 11 772 1433
Cell: +27 (0) 83 321 0544
Fax: +27 (0) 11 325 6680
Web: www.elb.co.za
ENGINEERED SOLUTIONS for LONG TERM RELATIONSHIPS
Confidentiality Caution: This email and all its contents are subject to the ELB disclaimer
Employee
Senthil-Autodesk
Message 4 of 5 (166 Views)
01-08-2014 01:51 AM in reply to: jacoj
Senthil Kumar
Vault QA Team
Valued Contributor
jacoj
Message 5 of 5 (149 Views)
01-09-2014 01:48 AM in reply to: Senthil-Autodesk
thank you This seems to fix the problem but seem the drag and drop capability is not working now because of the .NET 4.5 instead of 4.0 but at least the user is up and running again thank you
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
