Is there any way possible to convert data stored on a subscriber server into data that could be used to create a new publisher in the event of a catastrophic event at my publisher site? Think major fire/earthquake that takes out the site that is hosting both my publisher server and my backup.
I'm trying to come up with a disaster recovery plan where I could just use data already replicated to another site (away from danger) as the source material to restore my publisher.
The alternative is to take an ADMS backup from the publisher site and ship it to offsite storage to protect against this scenario. This plan has it's own issues (frequency, cost, etc).
Solved by ihayesjr. Go to Solution.
Scott,
Have you ever heard of Autodesk 360?
You might want to look into it for this situation.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
No, you cannot recover a Publisher from Subscriber data.
The Publisher must be restore using a Publisher backup.
