Hi
Actually, there is a Client using 5 network licenses of Vault Collaboration, but our client would like to migrate one of them to Vault Professional in order to control and manage changes, approval inside the vault (change orders), he will work with both products, Collaboration and Professional, my question is:
Is it Possible?
Will have any issue or compatiblity problem working inside the Vault with both products Professional and Collaboration in the newer versions 2013?
What would you recommend us about this?
Best Regards
Thanks.
you can't connect a vault collab client to a vault pro server and vice versa
you would have to setup a second physical server to run both products
don't know if you can replicate the databases since they are 2 different products
i would not recommend doing this
DarrenP
no two teirs of Vault may interact with other.
This includes replicated environments.
In short, all servers and clients must be the same tier of Vault.
yea pretty much
if you plan on upgrading to vault pro you have to upgrade everyone to vault pro
DarrenP
