Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault collaboration and 3ds Max
30 REPLIES 30
Message 1 of 31
mbaker
1693 Views, 30 Replies
Simple question - can't seem to find any information that 3ds Max has an addin for VC, is that true? I think files can be added manually, however I concerned with an account that needs to deploy 3ds Max and VC 2011 in a full replication configuration. Concern is the 3ds Max and the effect of a manual add to the Vault?
Thanks all
mb
30 REPLIES 30
Message 2 of 31
ihayesjr
in reply to: mbaker
MB,
Sorry but 3DS Max Vault add-in only works with our base Vault server which you can download through the subscription center.  It is not compatible with Vault Collaboration.
Irvin
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 3 of 31
mbaker
in reply to: ihayesjr
HI Irvin,
OK I think? It would seem that we need to do something for 3ds users whose teams are using the Collaboration tools. So only process is the add the 3ds models manually from the Vault Client application? Yes
Mb
Message 4 of 31
ihayesjr
in reply to: mbaker
You are correct.  The only solution available for you is to add the files manually with the Vault client application.  I will forward your needs along to see what we can do in the future.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Message 5 of 31
mbaker
Irvin - Thanks that helped...
Mike
Message 6 of 31
ihayesjr
in reply to: mbaker
Mike,
Have you downloaded the Vault add-in from the subscription center?
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Message 7 of 31
DarrenP
the vault add in for max comes with the max installation not with the vault client add in
DarrenP
Message 8 of 31
DarrenP
in reply to: DarrenP
see screenshot:
DarrenP
Message 9 of 31
DarrenP
from the subscription site: Note for 3ds Max and 3ds Max Design Users: You must install the Autodesk Vault 2011 Plug-in for 3ds Max 2011 from the 3ds Max or 3ds Max Design 2011 Installation Wizard to make Vault available from within the product.
the max design 2011 install wizard doesn't come the vault 2011 add in as you can see from the screen shot above
DarrenP
Message 10 of 31
ihayesjr
Mike,
Use Darren's suggestion to get the Vault add-in installed and that add-in should connect to the Collaboration server.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Message 11 of 31
DarrenP
i didn't really suggest anything
there is no vault 2011 add in for Max Design 2011
DarrenP
Message 12 of 31
DarrenP
installing the Vault 2009 add in fixed this (don't ask how i have no idea why)
Now max is showing the vault 2011 add in now
DarrenP
Message 13 of 31
hans.martin.haga
in reply to: mbaker
Is Vault Collaboration 2012 supported by 3d studio max 2012? To me it looks like 3dsmax only tries to connect using the base Vault client, which will not talk to the VC server.
Message 14 of 31
Message 15 of 31
ihayesjr
in reply to: hans.martin.haga
Yes 3DS Max 2012 supports connect to Vault Collaboration 2012.  You need to install the Vault add-in from the 3DS Max disc.  It is accessed through the 3DS Max Asset Manager.
If it is not on the media, you can download it from the Subscription Center.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Message 16 of 31
Bill.Schmid
How about 3ds Max Design 2013 and Vault Pro 2013?  I've got a whole inventor design in the vault that I need to get into max.  We're on subscription.  Is there a chance I can get a link to the add-in, if there is one?
Message 17 of 31
DarrenP
in reply to: Bill.Schmid
you can open from vault in 3ds max
Big M>open>open from vault
DarrenP
Message 18 of 31
Bill.Schmid
Open from Vault only works for Max files.  As I said, this is an Inventor file.  I need to Import and there is no import from Vault.
Message 19 of 31
DarrenP
in the open from vault dialog box select all files in the drop down menu for files of type
DarrenP
Message 20 of 31
DarrenP
nevermind that doesn't seem to check out the file
DarrenP
