In my Vault Collaboration 2011 Admin interface, I can't find the 'Apply rules on file creation' option (in Assignment Rules)
Is there a solution or SP to correct that ? The help file tells me that the option should be available in the bottom left corner
My install is in french and I am running Service Pack 2
Anthony
Hello Anthony,
Could you provide a screen capture of the 'Assignment Rules' dialog? It might help clarify what is happening.
Adam
Thank you for the quick response. I'm going to forward this on internally. I'll update you with any information I can gather.
Adam
I've found a solution to my problem...
Directly in the database, I found where the option is setup it is in the CategoryRuleSetCfg table of your Vault database
UPDATE CategoryRuleSetCfg SET ApplyRulesToNewEntity = 1 WHERE EntityClassId = 7
I don't really know what EntityClassId is but it's now working...
Anthony
Hi Anthony,
It's great it works now.
Maybe it's a localization bug, which language do you use? We may need to report a bug and fix it.
See the attachment for the location of the option.
Showching
Hotfix published for this issue, please check it from http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17265344&linkID=9261341
