I am unable to un-check the "Check Out Dialog" in the options window. See attached image.
Is there another setting some place else that needs to be toggled first?
Dave
Solved by Senthil_Kumar. Go to Solution.
Hi Dave,
You cannot un-check this option. This option is to Include the Children or not during Check Out. Be default Include Children Option is Turned Off. So the check out happens only on the selected file. If you want to include the children then you need to come to this option and change the settings to Include Children. In either case you won't see the Check out dialog.
Hope the above helps!
Well that is going to be quite annoying going forward. It was very usefull to be able to select that option within the check out dialogue. Why in the world would they need to create a new options dialogue that is supposed to give us more options yet decide for us we can't unsuppres the dialogue for check out! Now when you check out an assembly and mistakenly bring the children with it, you have to uncheck out the assembly, switch to Vault menu, make setting change and then check out the assembly again. I mean....really? AAARRRHHHHH!
