Hi Could anyone help me to map Vault Professional 2014 properties (Checked Date & Released Date) which is changed through Lifecycle to be mapped with Inventor Checked Date & Eng. Approved Date in Inventor iproperties. I beleive we can map "initial Released date" property of Vault with Inventor. But the problem is this date will not be updated with mutiple Lifecycle runs. Kindly help me out to find a solution to map these properties.
Solved by CGBenner. Go to Solution.
This is one of my gripes about the file release workflow in Vault Pro. Despite all it's flexibility there is no automated way to map the approver and release date to file properties outside of the initial release. If the properties "Initial Approver" and "Initial Release Date" existed less the "Initial" component, we'd be laughing! I'm not sure why the functionality was only implemented to track this based on Initial release only 😞
I've looked at this problem from all angles and I've found that the best way to handle this aside from customization is to create UDP's (e.g. Released by and Released date) which are assigned to the Category that the Inventor files belong to and mapped to the Inventor iProperties of your choosing. Then, prior to the user moving the file to released state, they edit these properties with the appropriate values.
-Ryan
Hi Ryan,
Thanks for your Prompt reply. Yes we will try to Develop a new UDP for this Case. Thanks for your Assistance.
Are there any news regarding this conversation?
Also see other articles in the Vault idea station: https://forums.autodesk.com/t5/vault-ideas/freigabedatum-property-erstveroffentlicht-immer-von-der/i...
Best regards
Dominik
Hi All,
Is there any way to do this property mapping. Recently we purchased Vault and looking for Work In Progress, Review and Released By mapping to .IDW file.
Hi, Are you using Vault Professional? And if yes, are you tracking life cycle changes on files or Items?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
This would need to be done with User Defined Properties (UDPs) placed on the files, and mapped to the Inventor iProperties. The values would need to be edited by the users as the life cycle is changed. One way to do this might be through the Vault ECO process, but I'm not aware of any way to automate the process from any existing properties.
Chris Benner
Hi
Thank you. As of now we are using UDP to get the date from Inventor, but i need to get it from Vault State change.
There is no way to automatically get these from a state change, as user defined properties, the values need to be manually edited by the user.
Chris Benner
Hello, I just found out about this idea in the Idea Station, which (if implemented someday) might help with your situation. I recommend that you visit the site, cast your vote and maybe add some comments about how this would help you in the future. Thank you!
Chris Benner
