We are currently using Vault Professional 2011, when an file is marked as being checked-out the only date showing is under the Checked In column. That date shown is 1/1/0001 12:00AM. Is there a way to shown when the Check-Out happened as opposed to this display.
I see no clear ways under the Customiz View option.
Thanks in advance.
This should be addressed in ts16172215
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16428729&linkID=9261341
[edit]
Pardon, the above hotfix will correct the behavior of the Check-in value returning 01/01/0001 when the file is checked out - I do not believe there is a method to customize what is displayed.
