So I am trying to set up a new Vault client on a computer and when I go to install it I get an error saying "Installation cannot proceed because not qualifying CAD applications were found....". After doing some digging I noticed this has to do with the fact that there are no 2014 Autodesk CAD programs installed.
Does anyone know if I download a 2014 viewer (I was thinking DWG TrueView and Inventor View for what I need) does that qualify as a CAD program? All I am setting this user up for is for read only so I don't want to install a full version of AutoCAD or another product because they will not be editing documents at all.
it requires an autocad based product or inventor to use free vault
this is not a requirement for vault workgroup or higher
the free viewer does not qualify
DarrenP
But once I install the vault client it doesn't need to open through one of those programs right? If I were to get around the install issue which shouldn't be a problem can I open from Vault with just the viewers? I don't see why I wouldn't because all I am using it for is file retrieval but just wanted to check before I go through all that work.
no the free viewers don't have a vault add in
DarrenP
Ok so maybe I am not fully understanding how it works, but with the vault client can't I download the files to the working folder and from there manually open the files using a viewer?
yes that could be possible
the vault client would have to be installed on another machine since this user will not have a qualifying CAD product installed
DarrenP
Does it only check during install? Or does the client require the presence of the qualifying CAD product at all time?
to install it
it does check for a qualifying cad product if it doesn't find one it will not install
DarrenP
the paid for Vault products do not require a CAD seat to be installed
DarrenP
Seems like a trial install of CAD would trick it? The reason I am going through so much trouble is I have an open spot in the vault but not additional licences for AutoCAD etc. adn because all they are doing is viewing documents I thought it wouldn't be an issue.
that should work
something your going to have to test
DarrenP
Ok cool, thanks for all of your input. Now that I know how that works it shouldn't be hard to figure out. Thanks again!
If all you want to do is view files, can't you do that using the dwf files that vault creates (assuming you have the vault set-up to do that)?
Then you can use any viewer/program that will open dwfs, no vault required.
There is an option in the vault to specify the location of the dwfs.
I may have this wrong. We are also in the process of setting up our vault. I have used it before at a previous employer, and we would view dwfs. I thought they were available in a public folder that did not require the vault to access. Maybe someone with more experience can help us out here.
