We are currently running 2014 versions of Inventor and Vault. I would like to upgrade to 2015. My server is currently running Small Business Server 2008 with SQL 2008 (SP3). Will Vault Server run properly in this configuration. I dont see SBS 2008 as a supported OS in the system requirements.
Please Help!
GFM
Hi gmatz,
Listed below is the link for the Vault 2015 system requirements. The listed system information is what is supported for the 2015 release.
http://help.autodesk.com/view/VAULT/2015/ENU/?guid=GUID-B64117E4-FA07-4145-8B5F-86973B13EB11
Kind regards,
Ron Smith
Hi Ron,
I have previously reviewed the requirements and didn't see SBS 2008. That's why I noted that I didn't see SBS 2008 in the requirements. That however doesn't mean the configuration will not work. It may not be listed since SBS 2008 is in Microsofts EOL cycle. Someone at Autodesk has started a support case. Are you responding on behalf of the support case?
Greg
Hi Greg,
I hope you are well. I am replying in the forum post rather than the support request. The requirements listed in the system requirements are what we support for the 2015 version. If the OS, you wish to use, is not listed, then it is not supported for use with the 2015 release. I hope this better explains the system requirements information we provide.
