Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Basic 2015 Install trouble: IIS is not running as the default web server
3 REPLIES 3
cw0547113
976 Views, 3 Replies
I am trying to install Vault Basic 2015 Server on Windows 2012R2.
I have to the point where it is running the checks and I get the error about "Acessing an http static file failed at URL http://localhost/TestASPNetStatic.txt".
I go to IIS manager and change the Application pool from "Integrated" to "Classic" and Re-Test, then all 16 Pre-Checks are Successful.
At this point the "Default Web Site" is running fine in IIS
I then click Continue.
The Install continues until a dialog box pops up saying "IIS is not running as the default web server".
I have verified that the Default website is bound to port 80.
I have corrected the hosts file so that localhost points to 127.0.0.1.
I have turned off UAC.
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\PLM does not exist in the registry on this server.
"Autodesk Vault Test ASP.Net" is not installed.
IIS is still running, but the "Default Web Site" shows status unknown.
Attached is the PreChecks log file and the Installation log file.
Thanks for any help...
Eddy
3 REPLIES 3
stuarts
in reply to: cw0547113
cw0547113
in reply to: stuarts
stuarts,
Pardon me if I am missing something here, but reading through that page, it appears that it is just running the Pre-Checks. Doesn't the installer do that by default? I attached the Pre-Check results to the orginal posting if that will help.
Is there a stand alone status check program that I missed?
m.mees
is .NET 3.5 installed on this server? I have seen various problems with installations of Vault 2015 on server 2012 when .net 3.5 was not installed.
Regards.
Marco
