Has anyone had frequent errors with the get/checkout process since upgrading to Vault 2014? We are currently using Vault Basic 2014 Build 18.1.8.0 Update 1. The attached screenshots show two examples. These errors will typically occur in succession - in other words, the first error will occur on the first attempt at opening a file from the Vault browser, & then the second error will occur on the second attempt.
The error occurs when right-clicking a file (ipt, iam, dwg, etc.) in the Vault program & then selecting open. As you can see, the error shows some sort of problem with the project file.
I have had errors like the one you are talking about with it enabled. Maybe try disabling and restarting the server and see if you still get them. Before you do that go into the IIS manager and see if any Autodesk IIS app have stopped running.
On Vault Client Side:
On Vault Server Side, when no users work:
