Hello Everybody,
I just installed Vault Basic 2014 and I'm still on the phase of figuring it out (never installed, set up or even used Vauld ever before...).
First thing I wanted to do is to set the default paths to a larger partition of my drive instead of the default C:
I managed to do that with the Database and the FileStore (made a backup and restored to a different location) and I would like to move the Working Folder as well, but whatever I do, it just won't change...
I tried:
1. File - Set Working Folder
2. Right Click on Root Folder - Properties - Working Folder - Change
3. Tools - Administration - Vault Settings - Enforce consistent working folder for all clients
Whichever option I try, I browse and chose the desired folder but the working folder just won't change.
It's probably something very obvious, but I just can't figure it out. So, any help would be appreciated!
Thanks in advance,
Baczo Zsolt.
Solved by z.baczo. Go to Solution.
Have you applied all Service Packs and Hotfixes?
No i didn't... But i reinstalled Vault and Vault server in reverse order and made some set-up choices in different order and now it works. But I don't know what made the difference.
