Hello Everybody,
I just installed Vault Basic 2014 and I'm still on the phase of figuring it out (never installed, set up or even used Vauld ever before...).
First thing I wanted to do is to set the default paths to a larger partition of my drive instead of the default C:
I managed to do that with the Database and the FileStore (made a backup and restored to a different location) and I would like to move the Working Folder as well, but whatever I do, it just won't change...
I tried:
1. File - Set Working Folder
2. Right Click on Root Folder - Properties - Working Folder - Change
3. Tools - Administration - Vault Settings - Enforce consistent working folder for all clients
Whichever option I try, I browse and chose the desired folder but the working folder just won't change.
It's probably something very obvious, but I just can't figure it out. So, any help would be appreciated!
Thanks in advance,
Baczo Zsolt.
Have you applied all Service Packs and Hotfixes?
No i didn't... But i reinstalled Vault and Vault server in reverse order and made some set-up choices in different order and now it works. But I don't know what made the difference.
