Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Backup with backup script? (x86) Issue
2 REPLIES 2
superslinky
739 Views, 2 Replies
Hey all, I need help with this. I think I know the problem and apoligize if this has been asked before. Basically I'm running a standard backup script:
@echo off
REM ********** CASCADE FOLDER BACKUP
SCRIPT************************************
REM ADMS Console 2010 Back Script
REM
echo %date% %time% Backup Started >> C:\VaultBackup
\Production_Vault_Backup.log"
REM Bounce SQL Sdfvice to release memory
REM NET STOP SQLAgent$AUTODESKVAULT
NET STOP MSSQL$AUTODESKVAULT
NET START MSSQL$AUTODESKVAULT
REM NET START SQLAgent$AUTODESKVAULT
REM Delete and Create Vault backup folders
RMDIR /Q /S "C:\VaultBackup\B"
Move /Y "C\VaultBackup\A" "C:\VaultBackup\B"
MKDIR "C:VaultBackup\A\"
REM Run ADMS Console Backup
"C:\Program Files (x86)\Autodesk\ADMS 2010\ADMS Console
\Connectivity.ADMSConsole.exe" -Obackup -B"C:\VaultBackup\A"
-VUAdministrator -VP -L"C:\VaultBackup\Production_Vault_Backup.log" -S
echo %date% %time% Backup Completed>> "C:\VaultBackup
This worked before we changed everything over to a windows 7 machine. Originally the path in bold above didn't include the (x86). Other than that everything else is identical. Does anyone have any idea if I have something wrong of if there is a work around?
2 REPLIES 2
Andy.Spivey
in reply to: superslinky
What error are you having when running the backup?  If it is a scheduled task, what does the result state?  (0x2?)
Can you execute the BAT file manually?
Andy Spivey
SQA Engineer
Dear superslinky,
Thanks for your posting.
Would you please try to execute this by command line?
"C:\Program Files (x86)\Autodesk\ADMS 2010\ADMS Console\Connectivity.ADMSConsole.exe" -Obackup -B"C:\VaultBackup\A" -VUAdministrator -VP -L"C:\VaultBackup\Production_Vault_Backup.log" -S
If this still not work. Please check all the locations in your commandline file.
If all the above still not work, please provide us more information:
1. Whar error dialog you got? It will be better capture a picture on that dialog.
2. The ADMSConsole log. (the default location in windows server 2008 is C:\ProgramData\Autodesk\VaultServer\Filestore)
Rohn
