Hello, Im having some trouble backing up our vault to a new location, the location is on a virtual machine but not on the same domain,
I have set file permissions for the domain user "Vault" to read/write on the new backup location and it works manualy when i just create a new folder ect but when the vault backup runs i get the follwing error in the backup log.
5/11/2013 9:12:56 PM User 'JMVMXXBY\Vault' does not have permission to path '\\jmvmYYby\backups\jmvmXXby\Temp\VaultBackup_2013_11_05_9_00_43_PM'.
5/11/2013 9:12:56 PM Connectivity.Application.VaultManager.ServiceException: InsufficientFilePermissions [175]
This is the backup script:
@ECHO OFF
REM CYCLE THE SQL SERVER
NET STOP MSSQL$AUTODESKVAULT /y
NET START MSSQL$AUTODESKVAULT
REM START Backup on Temp folder
"E:\Program Files\Autodesk\ADMS 2014\ADMS Console\Connectivity.ADMSConsole.exe" -Obackup -B"\\jmvmYYby\backups\jmvmXXby\Temp" -VU*********** -VP******** -L"E:\Backup\BakupLog.txt" -S
IF ERRORLEVEL 0 GOTO OverwriteLastBackup
IF ERRORLEVEL -1 GOTO End
:OverwriteLastBackup
REM DELETE 1 AND CASCADE TEMP BACKUP SUBDIRECTORY
RMDIR /Q /S "\\jmvmYYby\backups\jmvmXXby\Backup\1"
REN "\\jmvmYYby\backups\jmvmXXby\Temp" "1"
REM CREATE A NEW DIRECTORY FOR THE BACKUP
MKDIR "\\jmvmYYby\backups\jmvmXXby\Temp"
:End
REM Purge \\jmvmYYby\backups\jmvmXXby\Temp
RMDIR /Q /S "\\jmvmYYby\backups\jmvmXXby\Temp"
NET START SQLAGENT$AUTODESKVAULT
Any ideas or workarounds?
Let me know if more info is required.
Thanks in advance
