Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Backup Errors Missing file
1 REPLY 1
klbosch
300 Views, 1 Reply
Is the following error a sign of some bigger issue or simply that of a missing file.
5/24/2014 7:28:09 AM A file system error has occurred: Could not find file 'D:\...\000\000\000\040\001\025\40001025916\40001025916_40001025918_2.tif'.
5/24/2014 7:28:09 AM Connectivity.Application.VaultManager.ServiceException: IOError [179] (Could not find file 'D:\...\000\000\000\040\001\025\40001025916\40001025916_40001025918_2.tif'.) ---> Connectivity.Core.Exceptions.EncodableException: IOError [179] (Could not find file 'D:\Vault_Root\Filestore\TSG\000\000\000\040\001\025\40001025916\40001025916_40001025918_2.tif'.) ---> System.IO.FileNotFoundException: Could not find file 'D:\...\000\000\000\040\001\025\40001025916\40001025916_40001025918_2.tif'.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.File.InternalCopy(String sourceFileName, String destFileName, Boolean overwrite, Boolean checkHost)
at System.IO.FileInfo.CopyTo(String destFileName, Boolean overwrite)
at Connectivity.Core.Util.IOUtil.CopyDirectory(DirectoryInfo sourceDir, DirectoryInfo destDir)
at Connectivity.Server.Common.Services.FileStore.<>c__DisplayClass5.<CopyResourceStore>b__4(DirectoryInfo currentSource)
at Connectivity.Server.Common.Services.FileStore.WalkStore(DirectoryInfo currentdir, Int32 currentDepth, StoreDepth desiredDepth, StoreWalker walker)
at Connectivity.Core.Operations.Backup.BackupKnowledgeVault(DirectoryInfo databasesDir, DirectoryInfo filestoresDir, KnowledgeVault kv)
at Connectivity.Core.Operations.Backup.BackupKnowledgeVaults(DirectoryInfo databasesDir, DirectoryInfo filestoresDir, BackupContents contents)
at Connectivity.Core.Operations.Backup.Execute()
at Connectivity.Core.Services.KnowledgeMasterService.Backup(String& backupPath, BackupOptions backupoptions, ICollection`1 excludedLibraries, OnProgressDelegate onProgress)
at System.Runtime.Remoting.Messaging.Message.Dispatch(Object target)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg)
--- End of inner exception stack trace ---
Server stack trace:
1 REPLY 1
johannes.bauer
in reply to: klbosch
Hi klbosch,
thank you for your Message.
Question is, if it is expected that these files are missing. Vault would expect them to be there, otherwise he would not have searched for them to back them up. Where they deleted by accident?
Please check your machine's windows event log for hardware errors or anything you suspect that might have caused these files to be deleted.
HTH
Johannes Bauer
Customer Technical Successt
