Vault General Discussion
swalton
Message 1 of 5 (579 Views)
Vault Autonumbering and Copy Design
579 Views, 4 Replies
02-07-2012 03:30 PM
I am testing the Autonumbering tool with IV 2012 and Vault Collaboration 2012.  I like how it works with saving files from IV, but I can't figure out how to use it during a "Copy Design" command in Vault.
Is automatic numbering of copied files supported and where do I select the correct numbering scheme for my files?
Inventor 2014
Vault Professional 2014
Employee
achintam
Message 2 of 5 (575 Views)
Re: Vault Autonumbering and Copy Design
02-07-2012 07:02 PM in reply to: swalton
Currently Auto-Numbering is not supported inside Copy Design, however, we are looking at addressing this in a future release.  In the mean, you may want to consider working around it by renaming the Copied files by selecting the desired numbering scheme from the Rename wizard.  If you are okay with using the workaround, you can also consider using a Prefix/Suffix inside Copy Design, then search for all the files having that unique Prefix/Suffix in their name and perform a batch Rename.
Regards
Anil Chintamaneni (Autodesk)
Anil Chintamaneni
User Experience Designer
Data Management
koeltzsch
Message 3 of 5 (436 Views)
09-11-2012 02:32 AM in reply to: achintam
I skip posting a new thread about this topic.
I'll add here the same request to enforce the need of such a functionality. Both commands (numbering scheme and copy design) are very helpful functionalities inside vault but must be combined as soon as possible. It is absolutely inconvenient being forced to use the rename-command only to get auto-numbered the copied files. It's very time-consuming and leads to more unnecessary file versions.
We're facing more and more situations where this scenario occurs - that's why it would be greatly appreciated to have this issue fixed within the next vault release 2014.
Autodesk - please prioritize this!
Thanks and Regards,
DK
swalton
Message 4 of 5 (433 Views)
09-11-2012 05:35 AM in reply to: swalton
It would also be nice to be able to edit iproperties while in the copy design window.  That way I can fix my part descriptions without creating extra new versions.
Inventor 2014
steveh
Message 5 of 5 (424 Views)
09-11-2012 10:38 AM in reply to: swalton
Swalton...our best work around that we have found is to have Inventor open and do a saveas. Have it grab a number and do a copy from the filename line. Cancel out of the Saveas window and then go back to Vault and paste in the number in Copy Design. I know it's not ideal, but it's the best we got right now.
Inventor---Vault Professional
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
