Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault API .NET login
5 REPLIES 5
235 Views, 5 Replies
We are trying to do some tests with .NET and Vault/ProducStream 4.5. Unfortunately we get problems with the login part with .NET in the vault. (Copied from the samples). We have looked for solutions and tips in this discussion group and tried a lot of things without any result.
What is the resultscreen when we do a signin from the http://cadmatch-x4000/AutodeskDM/Services/SecurityService.asmx URL?
We get a server error HTTP 500 there.
Kind regards,
Guus de Groot CADMAtch BV
5 REPLIES 5
This sounds like a server-side problem. Can you access that page from a web
browser? Is there any thing in the vlog-YYYYMMDD.txt file on the server?
Jeff
wrote in message news:5111294@discussion.autodesk.com...
Kind regards,
Jeff,
I heard from someone that the samples won't work on ProductStream 4.5. Is this so? Do you know what's different in the first part (login) of the code?
I can acces the /securityservise.asmx page but the result is a 500 error. What do I have to see there?
Guus
If you're getting a 500 error when accessing via IE, the samples don't have
a chance to work. Can you see if there's any informaiton in the server-side
vlog file (there may not be). It's at %ALLUSERSPROFILE%\Application
Data\Autodesk\VaultServer\FileStore\vlog-YYYYMMDD.txt.
Or, perhaps are there errors indicated in the Application Event Log in Event
Viewer?
Jeff
wrote in message news:5112439@discussion.autodesk.com...
Jeff,
Guus
Jeff,
There are no errors in the event log. Herewith the vlog file.
Guus
This is a tough one to diagnose, since the log file doesn't indicate the
root cause of the error (we see a secondary error). So we're working a bit
in the dark. Often, this level of problem happens due to problems in the
basic web site compilation. Can you check the permissions on the
c:\windows\temp directory? The ASPNET user (under IIS 5), or the NETWORK
SERVICE account (under IIS6) needs to have full access here, as well as to
the Temporary ASP.NET Files folder under the
c:\windows\microsoft.net\framework\v1.1.4322 directory.
One thing that might help is to uninstall and reinstall .NET 1.1. This may
trigger a reset of the necessary permissions.
Jeff
wrote in message news:5113796@discussion.autodesk.com...
Jeff,
Guus
