This is a tough one to diagnose, since the log file doesn't indicate the
root cause of the error (we see a secondary error). So we're working a bit
in the dark. Often, this level of problem happens due to problems in the
basic web site compilation. Can you check the permissions on the
c:\windows\temp directory? The ASPNET user (under IIS 5), or the NETWORK
SERVICE account (under IIS6) needs to have full access here, as well as to
the Temporary ASP.NET Files folder under the
c:\windows\microsoft.net\framework\v1.1.4322 directory.
One thing that might help is to uninstall and reinstall .NET 1.1. This may
trigger a reset of the necessary permissions.
Jeff
wrote in message news:5113796@discussion.autodesk.com...
Jeff,
There are no errors in the event log. Herewith the vlog file.
Guus
