Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault API - Add new version of file and revise
3 REPLIES 3
1995 Views, 3 Replies
I am migrating documents from an old Vault-like application into Vault.
I have various files representing the versions of a certain document, let's call it TEST.dwg, where the revised versions are 0.2, A.2 and B. So, I have three TEST.dwg files, seperated in folders like: 0.2\TEST.dwg; A.2\TEST.dwg; B\TEST.dwg.
The Vault is already configured to accept this numbering scheme.
In Vault, I have created the folders and added the TEST.dwg file successfully (from version 0.2), using the AddFile function.
Naturally, everytime I try to add another version I get the Server Error 1008 indicating the file already exists.
But, things become tricky now that I want to add the other files, corresponding to the other versions.
In the end, I need to be in a state where the document needs the three revisions, corresponding to those three versions of the file.
Made some research in the API SDK documentation but found nothing indicating adding a file as a new version or revision (it'd be quicker if I could set as revised right after adding).
I have thought the following solution:
- Checkout to Workspace;
- Copy and replace the new .dwg;
- Check in again.
Don't know if this is also possible through the API.
But, I was looking for a more direct solution, since I need to migrate 40k documents or so.
Thank you in advance.
Tags (1)
3 REPLIES 3
Redmond.D
Upload and "set revision" are separate operations, you can't do them both at once.  The API function for setting the revision is DocumentServiceExtensions.UpdateFileLifeCycleDefinitions( ).
As for uploading new file versions, the workflow you described should work fine.  You always have to check out first before uploading a new version.  You can skip the copy step if you want since the CheckinFile function lets you upload from anywhere on disk.
Lastly, we have a discussion group specifically for Vault API questions:  http://forums.autodesk.com/t5/vault-customization/bd-p/301
So that's the ideal place to go next time you have questions like this.
Doug Redmond
Software Engineer
in reply to: Redmond.D
Thank you, that worked perfecly.
And sorry for posting in the wrong section, Vault Customization seemed as Vault Explorer customization only.
m.den.ouden
You can alse delete the file(s) first from vault then add again and then change the revision.
