Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
vault add in for autocad 2014
10 REPLIES 10
Message 1 of 11
Julian_Shepherd
1241 Views, 10 Replies
Hi all
I have got the ribbon panel showing in autocad for vault but it is blank.
I added the tool bar but when I click it the command line does not recognise the system variables for vault.
10 REPLIES 10
Message 2 of 11
Can you do a reinstall of the Vault Client from the Windows Program and Features and see if it works for you?
Samuel
Message 3 of 11
Tried re install still the same.
Message 4 of 11
Please try the command "cuiload" to unload the Vault Add-In and then load the Vault Add-In again using the VaAc.cuix customization file.
Samuel
Message 5 of 11
Tried solution still no luck
Message 6 of 11
Are you able to post a screenshot of what you are seeing?
Samuel
Message 7 of 11
screenshot attached
Message 8 of 11
Thanks for the screenshot. Some questions:
  1. Are you seeing this with a clean install?
  2. Other than AutoCAD 2014, do you have any other AutoCAD verticals (e.g. AutoCAD Electrical, AutoCAD Mechanical, etc.) installed on your system?
  3. If so, were there any removal of the AutoCAD 2014 and the other AutoCAD verticals Add-Ins done previously?
Samuel
Message 9 of 11
I have autocad michanical on my system but do not use it. I just opend it up and vault is fine on that.
Message 10 of 11
I believe that the AutoCAD Add-In is either uninstalled or removed by non-standard means from the system. Please try to remove the AutoCAD Add-In from Add/Remove Features by unchecking the option. And then repeat the process to get the AutoCAD Add-In back by checking the option.
Samuel
Message 11 of 11
Thanks for your help
