Edit from Vault Explorer will check out an Inventor file but the DWF file that was automatically attached, although copied to the working folder, is set to 'read only'. Consequently when the inventor file is modified and checked back into the Vault using the inventor browser - the DWF file is not updated and remains as per the previous version. This is causing problems with people viewing out of date drawings and I guess will cause problems going forward with Productstream.
Any suggestions would be most welcome
