wrote in message news:5167015@discussion.autodesk.com...
I have a large number of files that I tried to load into vault with the
Vault 5 Autoloader. These files are in my workspace. Some of the files in
my workspace are already loaded into vault, but some are not.
When I ran the autoloader, I was asked to map the workspace to a vault
directory. It seems that I must use the "Design" directory. That is not
part of my file structure. See the attached file. The file structure in the
Red box is what the autoloader added. The files in the subfold
ers "FMI Jobs" and "FMIPN" are duplicated in the existing Engineering
folder. I can't just "move" the files from the Designs folder to the
Engineering folder because the files already exist in the Engineering folder
and I can't be sure which is the latest version.
If I would have been able to map to the "Engineering" folder and not be
forced to use the "Design" folder, all of this could have been avoided.
Also when Autoloader got to the "Autoload Progress and Report", I got this
err
or message (see reply for ss). You can tell by the status bar that some of
the data was loaded. When I clicked "OK" the autoloader was closed.
Unless I'm missing something, the Autoloader is useless to me unless I can
map the folder to where I want it. Is there anyway that I can work around
this?
_______________________
I ran into the same thing. I already had a Vault set up, and a workspace
for it, and some files already vaulted, and wanted to get the rest of the
dataset uploaded. So I ran Autoloader, and it "helpfully" added the Designs
folder to my vault, and insisted that I really wanted to put the files there
rather than with the rest of my data. So the alternative is to go back to
using the 'add files' command from the Vault menu in Inventor. The
workflow, which I got to experience several times last week, goes like this:
1) Invoke the Add Files command.
2) Inventor spends about 90 minutes validating the dataset.
3) Inventor completes the validation, and begins pushing the data to Vault.
3) A few minutes later it crashes. We're sorry for the inconvenience.
Walt
