In the situation that an under laying Xref is revised and checked-in you will see in the thin-client, in the ‘uses’part of the screen from the Xref parent DWG, that the reference is updated. Actually the reference is not updated because the parent DWG is not been updated in AutoCAD. To present the actual situation you have in the fat-client the possibility to switch the uses-view from the latest to the previous version.
Two questions: How to show this actual situation in the TC? Is there functionality to check on ‘outdated’ drawings?
Thanks in advance,
Guus de Groot
