Hello everyone,
We are installing a replicated testsystem between two domains, with share a VPN connection across differente continets, before we install the productive system. The installed software is Windows 2012, SQL Server 2012 Standard with SP1 and Vault Professional 2015 on both ends. We have succesfully built the replication, but the performance ist really low (around 1 row/sec or even less). Is there any documented case like these? Which can be the reason?
In case you need more information I wil be pleased to share it with you.
Thanks in advance,
Carlos
Carlos,
Have you checked the bandwidth and latency of the VPN connection?
Hello Irvin,
thanks for the fast response.
we have a bandwidth of 40 mbps (theoretically, because the quality of the connection is variable) and a latency for 150 ms.
Kind regards,
Carlos
