From the document titled: Install Microsoft Sharepoint Vault Integration (http://knowledge.autodesk.com/support/vault-products/getting-started/caas/CloudHelp/cloudhelp/2014/E...
This is the step by step for creating the deployment....
Step #2.... are they referring to the Vault 2015 Server installation? Because I do not recall seeingSharepoint in the Configure section of that. Did I miss it? I see Revit integration... but no Sharepoint.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by cbenner. Go to Solution.
in the 2014 vault server installation it is there (see screen shot below)
it doesn't seem to be there for the 2015 installation
DarrenP
Yeah, Irvin Hayes has told me via Twitter that I should use the 2014 Integration once I have upgraded to 2015. Seems odd that it would not be a part of the installation, unless it isn't ready yet or something.
Chris Benner
Darren,
Does the Sharepoint server need to be on the same machine as ADMS server? Do you know? Anyone?
Chris Benner
No, and it is not recommended to have them on the same server.
Ok,
Got the integration program installed on SharePoint server. Attempting to run the Deplyall.bat. It is set to run a program called:
STSADM.exe. This file is elsewhere on the machine so the bat gives me a file not found error. if I change the path in the batch file to that location it runs STSADM fine, but cannot find AutodeskVaultBCSConnect.wsp. So the question is... where should the path be set? Our first attempt at this not only failed but now we cannot get into Sharepoint at all, we are getting a runtime error.
The good news, this is all in a sandbox... but still.
Chris Benner
Chris,
It sounds like you do not have a standard install of SharePoint if that exe is not in the location it has in the path. I would recommend that you fix your SharePoint login problem before trying to run the integration again.
OK,... got that all sorted out. We are now into the permissions. Business Data Connectivity Service, External Content Types. No External Content Types found. I used Deployall, and all sections gave me a "completed successfully" message. ADMS is runnin on it's own server... We're one step closer but still not quite there.
Chris Benner
Try the following:
Rename the .wsp file to .cab. This will allow you to navigate into the file just like with a .zip.
Inside the .cab file, you should be able to find a file called AutodeskVaultModel.bdcm. Copy this out of the .cab file and rename the .cab back to .wsp.
Go back to the BCS service in Central Admin. Check the External Systems view and remove AdskVaultLobSystem if it's there. Run the Import command point it to the AutodeskVaultModel.bdcm file.
After that, you should be able to progress to the next step.
Fantastic.
Thanks again.
Man I am going to owe you quite a few free beers in Vegas this year!
Chris Benner
Ok,... so close I can almost taste it. I can see the lists in Sharepoint, but when I click on one I get:
Error running BCS Command in Autodesk.Vault.BCSConnect: Server cannot be empty.
WSE 3.0 is installed on the SP server.
Also on entoering Vault login credentials, seeing:
Error: The EXECUTE permission was denied on the object 'proc_putObjectTVP',database 'SharePoint_Config', schema 'dbo'.
Anyone have any insights on this one?
Chris Benner
Try this:
Ugh. I lost what little IT help I've had this week. I'll have to look into this on Monday when they return. Thanks for the link.
Chris Benner
Well, this has turned into a journey into frustration. My head is aching from banging it on the brick walls. Since last Tuesday I have encountered and cleared error after error after error, in Sharepoint, in SQL, in ADMS.... and with every one I cleared (many with your help Irvin Hayes... thank you! ), another one would pop up in it's place. The latest one defies even a Google search, and none of our IT people have seen it before. All of this has been in the attempt to establish Vault login credentials for Sharepoint. Something I still cannot do. Here is the latest in case anyone out there has seen anything like it.
ERROR: Object Settings Name=Autodesk.Vault.BCSConnect.settings was updated by NTAUTHORITY\IUSR, in the w3wp (2468) process, on Machine SHAREPOINT14-1
Chris Benner
Chris, are you getting this error when you are saving the login information on the settings page?
Yes, this is when entering the Vault login information... Server, Database, User & Password. Also, I have tried to run the Autodesk.BDCModelEditor from the integration folder, and that just fails with a Windows "not responding" error. I assumed that was because there were no credentials setup yet.
Chris Benner
This sounds like you are still having a problem with writing to the SharePoint_Config database. Can you have your IT admin run a SQL Profiler on it to see if it is getting stuck? Also, make sure the FarmAdmin has the Execute permission on the database.
Also try the image that is in this thread.
Thanks for the help Irvin, but we've gotten nowhere with this. Inquiries on the SharePoint forums got me the advice of asking my question here. Once again I am without any IT support until at least tomorrow morning. No one seems to know if this is a problem with Vault, SharePoint, SQL, IIS (on either server)...
Chris Benner
Finally resolved this annoying error. Our IT guy found an old SharePoint 2007 blog that described a procedure for clearing cached files from the database. He followed the instructions, and now we're in business.
Chris Benner
