Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault 2015 Server Basic Install Pre-Check Error
5 REPLIES 5
Aldred
678 Views, 5 Replies
Hi Everyone,
I am having an issue with the pre-check for Vault Server Basic 2015.  I am installing on Windows Server 2012 and using SQL 2012.
This is the error message that it gives.
Checking ASP Status:  Accessing an http static file failed at URLhttp://localhost:80/TestASP/TestASPNetStatic.txt.
When going through the steps in the help files  to see what the problem is I type this in the run command.
c:\windows\microsoft.net\framework64\v4.0.30319\aspnet_regiis -i -enable
I get this error.
Microsoft (R) ASP.NET RegIIS version 4.0.30319.17929
Administration utility to install and uninstall ASP.NET on the local machine.
Copyright (C) Microsoft Corporation.  All rights reserved.
Start installing ASP.NET (4.0.30319.17929).
This option is not supported on this version of the operating system.  Administr
ators should instead install/uninstall ASP.NET 4.5 with IIS8 using the "Turn Win
dows Features On/Off" dialog,  the Server Manager management tool, or the dism.e
xe command line tool.  For more details please see http://go.microsoft.com/fwlin
k/?LinkID=216771.
Finished installing ASP.NET (4.0.30319.17929).
Has anyone seen this and how do I fix it.
Aldred
5 REPLIES 5
scottmoyse
in reply to: Aldred
Have you tried doing what it suggests?
Before you though. Uninstall .Net Framework and let the installer install it itself. BUT, you will need to make sure that doesn't affect anything else which may be running on the server.
I think there are a couple of articles posted by resellers online detailing steps to install Vault 2015 on Windows Server 2012... its straight forward on R2.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
samuel.seah
in reply to: Aldred
Hi Aldred,
Please launch command prompt in administrator mode and run this command:
%windir%\system32\DISM.exe /Online /Enable-Feature /FeatureName:IIS-ASPNET45 /All /quiet /NoRestart
-Samuel
Aldred
in reply to: scottmoyse
Hi Scott,
I didn't wan to uninstall and reinstall as we were worried that it might break the sharepoint running on the server.  I have contacted autodesk and they will be assisting this afternoon with the install.
Thank you for your reply.
scottmoyse
in reply to: Aldred
Here is the blog post I was referring to in case you still need it.
Scott Moyse
Aldred
Hi Everyone,
Thank you for all the suggestions.  We discovered we cannot run Sharepoint and Vault Server on the same Server.
Aldred
