I'm trying to set up Vault Pro 2015 on my home WIn 7 64 bit PC as a standalone installation to test it before I install if on my office server. I'm NOT using LMtools - just the standalone versions of all Autodesk products.
I keep getting the "Failed to acquire licence" message, I've looked at various posts and have isabled IPv6 and changed the Licpath to 127.0.0.1 etc but keep getting the same message.
Autodesk Data Management Server is installed on the same PC and appear to be running ok.
Can anyone help me please.
Solved by Neil_Cross. Go to Solution.
I see two separate issues, first one being that Vault Pro (ADMS) isn't 'officially' supported on a desktop OS... that's a thing but definitely not the issue here.
Secondly, and more crucially, Vault Pro will not work at all without a valid license being issued via the LMTools license manager. There's no trial for Vault Pro, no standalone version, no nothing without a license being issued by a license manager.
So basically, what you're experiencing is kinda normal, you're not setting it up wrong, you just need to access a license. If your office has a license manager installed with a 2015 license available, maybe VPN in and grab it that way.
Neil
Thank you for your reply. I run an ATC specilaising in Standalone AutoCAD so Vault and LM Tool is new to me. However being an ATC does mean I can get whatever software I want.
Bearing that in mind what is the best way to set this up. I have Vault Pro, ADMS, Vault Basic (as part of Inventor Professional Design Suite) and eventually wish to set Vault up on a workgroup of 6 Networked PC's currently connected to a NAS box acting as a file store. Before going "live" I want to trial Vault on a single PC at home or on my laptop to see if it is what we really want. If it means evetually buying a proper networked server then I will do this, but only as a last resort as we are a small company who do not understand the workings of a server and dont want expensive maintenance.
I have since installed LMTools on my PC but not yet configured it.
Would my situation mean having to use Vault basic or workgroup, if so what are the steps required for installation, particularly regarding getting these to connect to a "vault". I would prefer to keep to the professional option if possible.
Any advice is greatly appreciated.
you may want to do some research on this first
i would not recommend going at this if you have never done this before or partner up with a reseller in your area for some onsite services so you can see how to set this up the correct way because if you set up wrong it will leave a bad taste in your mouth and you will think the product doesn't work
i would start reading about vault here: http://knowledge.autodesk.com/support/vault-products/getting-started/caas/CloudHelp/cloudhelp/Help/E... and http://knowledge.autodesk.com/support/vault-products/getting-started/caas/CloudHelp/cloudhelp/2015/E...
DarrenP
in your situation i would use Vault Pro and skip Vault Basic
DarrenP
