Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault 2015 Illegal Characters When Performing a Copy Design
4 REPLIES 4
shawn.payne
500 Views, 4 Replies
When performing a copy design I get a illegal characters error and the copy design cancels. At the time of the error the progress bar is on library parts that are set to reuse. It should not be doing anything with these parts so why could it cause the error and how can I correct it?
4 REPLIES 4
john.laidler
in reply to: shawn.payne
Does your filename or folder path have any 'special characters'?
Such as:  #, $, %, &, " (quotes)
John Laidler
AutoCAD, Inventor and Vault
Please use "Accept as Solution" & give "Kudos" if this response helped you.
shawn.payne
in reply to: john.laidler
There is a hash tag on some of them for 150# flanges. That has been like that for a long time and never caused problems. Other assemblies can copy without that problem. After 4 tries the copy design worked. This happens once in a blue moon.
john.laidler
Do you have a default Inventor Project file established within the Vault?
John Laidler
shawn.payne
Yes
