Can I simply change the location of my daily Vault Backup if I install another HDD in the same server...???
Reason being is that I have a 500Gb RAID drive which only allows me to have a third of it's capacity because there is the daily backup and then the old backup from the previous day. i.e. approx. 170Gb of Vault data is the MAX.
If the backup went to another built in HDD i.e. an F:drive would I simply be able to change the drive letter in my script file.
Thus giving me more usage of the 500Gb RAID drive.
I currently use the following script.....
@echo off
net stop "Autodesk Data Management Job Dispatch"
net stop MSSQL$AUTODESKVAULT
net start MSSQL$AUTODESKVAULT
e:
cd\vault
cd "Vaultbackup"
rmdir /s /q old
move /y VaultBackup* old
c:
cd\
cd "C:\Program Files\Autodesk\ADMS 2015\ADMS Console"
Connectivity.ADMSConsole.exe -Obackup -B"e:\vault\Vaultbackup" -VUadministrator -VP -L"e:\Vault\Vaultbackup\BackupLog.txt" -S
rem Purge database- keeps only latest version for database RCcar and misses files with comment do not purge.
rem Connectivity.ADMSconsole.exe -Opurge -KEEPVERS3 -MINAGE0 -EXCLCMT"Do not purge" -Nvault -VUadministrator -VP -L"e:\Vault\VaultBackup\BackupLog.txt" -S
Connectivity.ADMSconsole.exe -Odefragmentvault -Nvault -VUadministrator -VP -VAL -L"e:\Vault\VaultBackup\BackupLog.txt" -S
Solved by paul.gunn. Go to Solution.
There should be no problem changing the backup location. To Vault one drive is as good as the other.
Paul
