Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault 2015 - Application Preferences settings
1 REPLY 1
RamRamalingam
468 Views, 1 Reply
Below is the issue we ran into while trying to install / deploy  Vault 2015/Inventor.
The question is to publish common defaults for Vault Login prompts on client machine.
We had a couple questions:
  1. Following the steps below are for the 'ApplicationPreferences.xml':
    1. Is there another location with the “original” file is located before it is copied into the user’s Windows profile? (i.e. “C:\Users\yzhytko\AppData\Roaming\Autodesk\Inventor 2015 Vault Addin\ApplicationPreferences.xml”)
  1. We also noticed that even changing the property didn’t change what was displayed to the user when launched via a Citrix published session (We changed UserName Value, DatabaseName and ServerName but still presented to user is what was originally in xml file)
<?xml version="1.0"?>
<Categories xmlns="http://schemas.autodesk.com/msd/plm/Preferences/2006-04-11">
  <Category ID="Login">
    <Property Name="AutoLogin" Value="False" />
    <Property Name="ServerName" Value="" />
    <Property Name="UserName" Value="username" />
    <Property Name="SelectedAuthenticationType" Value="0" />
    <Property Name="Password" Value="" />
    <Property Name="DatabaseName" Value="" />
    <Property Name="Expanded" Value="True" />
  </Category>
  <Category ID="WorkListManager">
    <Property Name="RefreshInterval" Value="300000" />
  </Category>
  <Category ID="GeneralOptions">
                <Property Name="IgnoreCheckInMachineNameValidation" Value="True" />
</Category>
</Categories>
1 REPLY 1
ihayesjr
in reply to: RamRamalingam
Vault is not Citrix Ready and therefore not supported in a Citrix environment.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
