Loving the new Vault web client interface! Great to now see UDP's, Where Used and Uses, as well as a more intuitive interface in general. Some initial issues though:
1. When using Google Chrome (ver 30), there is no option to show the associated DWF file:
However, in IE10, it is there:
Is this a setting in Chrome? I tried to follow the help file to configure Chrome, and everything seems to be OK.
2. Opening the DWF file in ADR:
Gives the error:
This is with a fully updated ADR2013 (Build 13.0.0.82)
Any suggestions?
I'm glad you posted this as I am experiencing the same issue... no preview in Chrome but works in IE
Hi Irvin, thanks for the prompt response. The workaround does work, but is that really the expected action at this stage? What would be the correct workflow to open this up in a full-window? The View in Full Screen works, but then all the toolbars of ADR are gone.
Thanks!
The unfortunate part is that with new technology comes new challanges. I will have the development team see what we can improve in this area.
Hi
Can the default DWF window in the new client be sized?
I agree that it's not very usefull when going full screen that we loose all the Design Review Tools
Secondly, is there any option to stop users from downloading native CAD file?
Max B
I second the request.... why can we not resize the DWF Preview Window? or at least why isn't it full screen?
Mike
Can one of you created the wish in the IdeaStation?
Windows Auth does work with the new client. I believe something must not be configured on your server.
how about Mozilla Firefox? While I can view the DWF files with the ADR Plug-In for Firefox installed in the old webclient it doesn't seem to work within the new webclient.
Can you confirm this issue like with Chrome in your first post?
Regards.
Marco
No it doesnt, it only works with google chrome, no luck with firefox or IE, and you know chrome doesnt support 3D preview, so I'm stuck with the old webclient for now.
the only workaround I have found so far is this (attached) which is not an option for us, it takes time and we cant do it.
Hi 3DAli,
Coul you elaborate on on IE not working with Window Authentication? Was it:
1. WA user cannot even login, or
2. WA user could login, but you're seeing error in the landing page?
etc?
Thanks for your patience...
Chear Huat
