If you are on a local LAN, you shouldn't need to configure FQDN. Only use the FQDN if you are connecting to Vault over the internet. If you are having a connection problem while on your LAN, note the error message, and search this blog:
http://crackingthevault.typepad.com/crackingthevault/
Otherwise, Step 4 should say, Right-click the Default Web Site, Manage Web Site, Advanced Settings.
I just realized those instructions were written for a prior version of IIS. Please try these instructions:
To configure the Vault Server to allow remote connections over the internet using a Fully Qualified Domain Name (FQDN):
I still have some questions for you. My server is running windows 7 and i read on the internet that it's impossible to establish remote connections on iis on win 7 (http://technet.microsoft.com/en-us/library/cc731771(v=ws.10).aspx). Are you sure it can be done (access to my vault remotely) with my server running windows 7???
I have another question. In the "binding" box of iis i already have an option set (http for protocol, * for ip, 80 for port and blank hostname).
I'm guessing this one is for the local use of the vault (which, as i have already wrote, works perfectly) and i was wondering: in order to "add" a remote connection to the local one do i have to edit the one already existing or do i have to create a new one (in order to keep both the local and the remote connection working)?
One last thing, let's just say i buy a domain from godaddy.com. To get a fqdn i'd have to create a host like this "myservername.domain.com" and then point it to my server ip address right??? The problem is that my server has a dynamic ip and in order to get a static one i should create an account at no-ip to get a static host and than point my fqdn at this host right??? Or do i need to get a "real" static ip in oder to use it with the fqdn??
And finally, what ip should i set on the binding section of iis for the remote connection?? My server ip, the fqdn ip or the local ip (example 192.168.0.1) from which i access my server in local?
That article is written for Windows Server. I believe that topic is different than what you are trying to accomplish.
Honestly I have not personally setup a Vault connection via FQDN. Hopefully someone else in the community can contribute here.
As for the IIS bindings, you would add a binding. Keep the current blank with port 80 for the local connection.
Another thing to consider is if your ISP allows you to run a server. Some ISPs do not allow it.
