Does the new version of Plant3D replicate all databases across multiple Vaults using Vault Professional 2014?
We are trying to upgrade the system to a 2014 setup and will be upgrading from Plant3D 2013 Extension 1 to the latest 2014 version but 2013 had a limitation of not replicating the databases with the Vault, is this still the case or has it changed?
Solved by ihayesjr. Go to Solution.
i don't think anything changed from 2013 extenstion 1 to 2014 as far as vault functionality goes
but i could be wrong
DarrenP
No, the Plant 3D database isn't replicated in 2014.
