Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault 2014 - Lost Admin password
5 REPLIES 5
2050 Views, 5 Replies
is there a way how to reset Admin password? We lost it. Probably somewhere through SQL in Management Studio? Cany anyone help us with that? We quiet hurry on that 😞
Thank you
5 REPLIES 5
Are you running a Vault backup in task scheduler?  If so, look at the .bat file and it sould have a User and Password that has administrative access.
minkd
I think you will need to open a support case - either via the subscription portal if you are on subscription, or via your reseller otherwise. I believe Product Support has a utility to reset the "Administrator" password (assuming you are using Vault Authentication). -Dave
Dave Mink
Fusion Lifecycle
in reply to: minkd
SO there is no way to do it by yourself?
Nevermind, i will open case then 🙂
Thank you Very much.
j_weber1
If you have another user with administration rights you can perhaps login to the adms as this user.
than you can modify the user administrator and delete the passwort and set a new one
changing the passwort over the sql managemant is possible but you must have a default value
Jörg Weber
CAD Systemtechniker für AutoCAD, Inventor, Vault
in reply to: j_weber1
What do you mean by the default value? Default value for default admin is blank password 🙂
But if we had one more admin then yes we could just chang it, but we don't have 🙂
