Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault 2014 Integration in Sharepoint 2010
2 REPLIES 2
florent.rodriguez
288 Views, 2 Replies
I have a problem in deployment of Vault in Sharepoint.
When i run deployAll.bat all operations are done sucessfully
But there are no bdc "external content" added in sharepoint.
How can i fix this ?
2 REPLIES 2
This happens in some deployments, but I don't know why.  The workaround is to manually import the BDC file.
Here are the steps...
Rename the .wsp file to .cab.  This will allow you to navigate into the file just like with a .zip.
Inside the .cab file, you should be able to find a file called AutodeskVaultModel.bdcm.  Copy this out of the .cab file and rename the .cab back to .wsp.
Go back to the BCS service in Central Admin.  Check the External Systems view and remove AdskVaultLobSystem if it's there.  Run the Import command point it to the AutodeskVaultModel.bdcm file.
After that, you should be able to progress to the next step.
Doug Redmond
Software Engineer
Autodesk, Inc.
It works perfectly , Thank you
