I just install Vault Pro on my machine. I have AutoCAD 2014 and 2012 installed, I can only find VAult add-in for 2014, not for 2012. Is it possible to make vault work with 2012 and 2014 on same machine?
Thank you,
Wes
Solved by ihayesjr. Go to Solution.
You will have to install the Vault 2012 client to get the AutoCAD 2012 add-ins. However you can keep your 2014 server and both will connect to it.
