Hi All
We have setup a test Vault server with the following setup
The server was also setup according to the Vault Advanced setup guide.
After this we are having connection issues trying to connect to Vault Basic Server 2014 with the 2013 Client. We get an error that I have attached. It is similar to the error shown in the following post
http://forums.autodesk.com/t5/Autodesk-Vault/Problems-after-installing-Vault-2014/m-p/3910192#M47342
however a restart did not fix this. The following was also run and returned what it should as mentioned in the same post. http://<server>:<port>/autodeskdm/services/filestore/v18/authservice.svc
In our case the 2014 client connects to the server but the 2013 client cannot. Could this be a windows update issue as Vault client 2013 should be compatible with the 2014 Server?
