We are getting ready to install Autodesk Vault 2014. We currently use multiple Autodesk 2012 products (Civil 3D, Electrical, AutoCAD LT). Update of the Autodesk 2012 products is months away. Will we need to install the Autodesk Vault Addin for 2014 onto each users computers or can each user use the 2012 Vault Addin they currently have?
Solved by herrerh. Go to Solution.
The Vault 2012 Add-in for your 2012 products will allow you to connect to Vault 2014. A Vault 2014 Add-in is not available for 2012 products, use the 2012 add-in.
-Hywell
As above but also make sure the Vault 2014 ADMS has all the patches & updates, as well as the 2012 Client/Addin on all the PC's with Inventor 2012. Naturally you would want to make sure Inventor 2012 also has all the latest updates.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
