Hi all,
I've tried to upgrade Vault 2013 to Vault 2014. This has gone wrong. I removed ADMS 2013, tried to install ADMS 2014 but get 232 errors. After searching the fora's I thought it could have to do with the problem of installing Vault after changing the regional settings of the server. The server is a Windows 2008 server with SQL 2008 standard. The OS is English, but regional settings where set to Dutch. So I removed all vault installations en instances, changed the settings to English, reinstalled SQL 2008, created a AutodeskVault instance and reinstalled ADMS 2013. Then I was able to restore a backup of the Vault and we are up and running again. Now I would like to create a 2nd Vault for Archive purposes. Our primary Vault (working vault) has a database size of 16,78 GB and a filestore of 383,96 GB.. So pretty huge. I want to move some projects from the 1st Vault to the 2nd Vault.
But when I try to create a 2nd Vault I get an error: An error occurred when applying configuration. See the log for detail.
11/28/2014 11:46:20 AM Loading configuration 'D:\#AutodeskVault\v2013\ADMS 2013\Server\VaultScripts\Config\VaultAppVaultSystemData.cfg' - section 'PropertyDefinitionContentSourceMapping'
11/28/2014 11:46:20 AM An error occurred when applying configuration. See the log for detail.
11/28/2014 11:46:20 AM Connectivity.Application.VaultManager.ServiceException: ConfigurationError [232] ---> Connectivity.Core.Exceptions.CoreException: ConfigurationError [232] ---> Connectivity.Core.Behaviors.Util.XmlCtntSrcPropDefMappingException: UnknowContentSource [4501]
at Connectivity.Core.Configuration.SectionHandlers.CtntSrcPropDefMappingSectionHandler.LoadHandler(IConfigSection section)
--- End of inner exception stack trace ---
Can anybody help me with the 232 and 4501 error?
Somehow the vaultmanager has an link to C:\Server\components\contentsourcepropertycfg.xml, but that should be a relative path, because this directory doesn't exists on the C: volume, but on another volume. How can I resolve this?
Thanks in advance.
Kind regards,
Leander van Gorsel
Three weeks on the forum, and no respons... That's a pitty..
I'd start by checking the web.config file (probably under D:\AutodeskVault\v2013\ADMS 2013\Server\Web\Services). Maybe there is an error inside there and it can be solved by deleting the "#" symbol in the path.
Regards.
Marco
