Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault 2013 Service Pack 1 Build No.
3 REPLIES 3
loesche1
381 Views, 3 Replies
Hello all!
Has anyone already installed the Service Pack 1 for Vault 2013 that was published on June, the 4th?
After installation the info says it is Build 17.1.16.0 Update 1 - but that can already be found on the machines that don't have the SP installed yet!?!?!?
Has the installation failed or is there a bug in the renaming of the SP? Is there another possibility to check the actually installed SP?
Best regards!
3 REPLIES 3
samuel.seah
in reply to: loesche1
You can go to Control Panel -> Program and Features -> Installed Updates to check if any updates for Vault have been installed.
Samuel
loesche1
Hi Samuel!
Thanks for your reply! This is a good way to check if the SP is installed. But I find it a bit confusing that this information can't be found within the software itself. Maybe it's time for an update for the SP...
samuel.seah
You will be able to check it in the Help -> About dialog of Vault Client/Server
