Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault 2013 not extracting iProperties
6 REPLIES 6
337 Views, 6 Replies
If I create a new Inventor 2013 DWG file and check it into the Vault, the iProperties are extracted correctly. If I checkout an existing DWG file from the Vault and check it back in, the iProperties are not being extracted correctly. This issue does not seem to be appearing on all computers and all users.
6 REPLIES 6
cbenner
scottmoyse
Any specific iprops or is it random? Do some work while others don't?
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
in reply to: scottmoyse
Seems like the same results from computer to computer with the same files. Also, it appears to be only affecting DWG files. But like I said, it's only existing files and not new files so that is what is so bizzare and hard to figure out what's going on. All service packs on client and server are up to date.
cbenner
Probably too obvious, but have the property names changed at any time?  Just trying to catch everything I can think of... which ain't much!  Smiley LOL
I assume you mean Inventor DWG's?  Are all of your property mappings right?
Still no progress with this issue.
herrerh
Thomas,
Make sure you are up to date on Service Packs, Updates and hotfixes including the following which was released today for property issues.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22354869&linkID=9261341
-Hywell
Hywell Herrero
Data Management Support Specialist
Product Support
Autodesk, Inc.
