Seems like long time nobody suffer from error 1316.
We now have one file (Configuration member Inventor 2012) with inability to Assign Item.
SQL maintenance plan is set properly.
Any ideas?
We have seen an issue like this reported in Vault Professional 2013, but it was addressed after a customer provided the files causing the issue to Autodesk.
It sounds like this is a similar issue, (but obviously different as the other issue was addressed in SP1) so is it possible to share the file(s) involved to Autodesk Support?
Richard
I wonder can entry from vlog be of some help to determine the reason of the issue?
06.05.2013 23:35:06 *******************************************************************
Error: Soap Exception ( mesg-id = 635034801061737132 )
Exception: PromoteFileIterationsFailed [1316]
Stacktrace:
Server stack trace:
at Connectivity.Product.Services.ItemService.ProcessBOMBlobs(Hashtable allboms, ArrayList newBoms)
at System.Runtime.Remoting.Messaging.Message.Dispatch(Object target, Boolean fExecuteInContext)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg, Int32 methodPtr, Boolean fExecuteInContext)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Connectivity.Web.Services.v17.ItemService.AddPromoteComponents(Int64[] fileIds)
Exception(Inner): Index was outside the bounds of the array.
Stacktrace(Inner): at Connectivity.Product.Services.ItemService.ProcessBOMBlobs(Hashtable allboms, ArrayList newBoms)
Just in case, IAM re-assembled "from scratch" using that same components and checked-in to Vault creates no problem on assign item operation.
Has anyone found any resolutions to this besides "rebuilding" the assembly? I have two users getting this error with some iAssemblies. Any help would be great!
For others seeing this, in one situation we found that this helped.
