There was an update that addressed this, since you have Update 1... I can only guess it was 2 or 3. I suggest getting up to date on these and see if that fixes the problem. I've read that this was covered in one of them. If that still doens't fix it, I would recommend logging a service ticket.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
If you can still repro this to be an upgrade problem with .NET 4.5.1, from say .NET 4 or 4.5, then please send the details about the issue to "netfx45compat" and we can help investigate.
Of course, you should verify if this is not a problem with the app first (i.e. missing updates).
Can you also let us know from what version of .NET did you upgrade from?
Vivek Mishra - MSFT
The .NET 4.5 issue is supposed to be fixed in 2013 SP1. We have Update 1 installed. So in theory this should have been fixed.
We have a workaround right now where we uninstall 4.5.1 and then reinstall 4.0. This fixes the problem.
Thanks Gary.
Since, I am from the Microsoft .NET Framework team, I was more interested in the break after the upgrade from 4.0 to 4.5.1.
If it is not too inconvenient, it will be great if you can send some more details (like crash dump, system event log entry, functional scenario broken) on the issue to netfx45compat @ Microsoft com.
Note that .NET Framework 4.5.1 (KB2858725) has been deployed to Windows Update so over time this will start replacing .NET 4 on end customer machines, unless you choose to specifically block it.
Vivek Mishra - MSFT
Hi Gary,
Do you mind sharing the following information:
1. The version number of your vault pro 2013
2. Is there any Service Packages patched to your Win7 OS?
3. Was there any error message popping up when you launch the vault immediately after .NET was upgraded to .NET4.5.1?
These information would be greatly useful.
Jiao
