in Vault 2012 MS office 2010 (64 bit) the add-on did not work, but in the new version I cannot find the new add-in to work with Office 2010 64-bit. I hope Autodesk fixed this in this release!
We only have the 64-bit version of office 2010.
Danny
Solved by Lynn2009. Go to Solution.
it should come up during the installation setup and/or deployment creation
DarrenP
is it not showing up?
DarrenP
Hi Danny,
Thanks for your posting. We do support 64 bit office 2010 Add-in in Vault 2013.
After you installed MS office 2010 64 bit, please go the add/Remove feature tab of vault client installer ("programs and features --> uninstall/change Vault 2013 (client) --> Add or Remove Features"), and you can find a feature "MS Office Add-in(64-bit)", check it and you can install Office 2010 (64bit) Add-in.
And we have a defect in this case, Currently, the "MS Office Add-in (64 bit)" item was wrongly shown as "MS Office Add-in (32bit)" in non-english version (as attachment), it is just a description error, and actually it will install 64 bit office Add-in for you.
Regards
Lynn
Hi Lynn,
I found the add/remove features and checked the option, I've installed the English version, my german is pretty bad...
It worked! thanks.
