Installed Vault 2012 SP1 on vault server without issue, but when installing the client version, we're getting this:
It's occuring at this point:
UAC off
Windows updates installed
Antivirus disabled
What should we try next?
Thanks.
Bob
Solved by Richard.Rankin. Go to Solution.
Solved by Greatwhitenorth. Go to Solution.
inspite of TS.... We have at least on case where it is impossible to install the SP1. ...the same issue...
Regards
Mario
Thank's Richard,
This patch work fine. But I have on question.
How can we make to apply this patch on a deloiemment. I must deploy 20 PDSU 2012 with vault and i will install the Sp1 too.
regards,
Dominique
You apply this patch the same way as you attach sp1 to the deployment. Dowload the patch and sp1. First attach the patch and then sp1 to the deployment.
I've used it on several installations, works completely ok.
...but the patch and the SP1 could not be applied in a scenario with Valt Professional and Product Design Suite or I'm wrong? We have PDS with Vault Professional nor Vault.
Thks!
As far as I know you don't need the patch for Vault Pro, only for standard Vault from the suites.
SP1 client-side won't install in Vault Pro as the problem in this 3rd and the patch could not be applied cause the clients have Vault Pro...
That's the same what we have, SP1 failed, and the fix failed because auf Vault Collaboration...
Regards
mario
Thanks, that worked for us. Why isn't this documented on the page where the update is downloaded????
Why don't Autodesk just recompile a new Vault 2012 Client install. The latests Hotfix has now created a new problem. The inability to "purge" old versions. Our companys faith in Autodesk to deliver a stable product is quickly disappearing.
