I Have never had this happen to me before....
i can see the 2012 standard Libraries that installs, but if i create a read/write Library in ADMS i cant see it when i
go to CC Editor or when i go to the project and try and attach the library.
in 2010 i had no issues.
also if i create a read/write library in CC Editor it should update ADMS right? its not.
lastly i have 2 read/write libraries that i copied from 2010 to 2012 Libraries and they are on the 2012 Partition but cant see
those either.
someone Please advise me on how to fix this. i am running a teat vault and cant go live until this is resolved.
thank you in advance ....
Solved by Andy.Spivey. Go to Solution.
jpchaisson,
Do you see your custom CC libraries when viewing the CC options in your project file?
If so, please make sure that they are selected and the project file is saved.
Also, please make sure that Inventor is set to look for your CC information from ADMS and not the Inventor Hosted Content (Tools -> Application Options -> Content Center)
Thank you for the fast response you are awesome.
ive been running in circles and never though of looking in Application Options. i can kick myself in the A$$ really hard.
if i could shake your hand i would thanks again.
