Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault 2012 crash AutoCAD when check in
6 REPLIES 6
wesbird
615 Views, 6 Replies
  I just installed a couple of machine for extend testing. normally, I login as my name with admin permission to install Vault Pro, CAD Addin, Office Addin. When my co-worker login as her name, she cannot see the Vault ribbon in AutoCAD, so I copy vaac.cuix, load it, then the ribbon appear. Now she open (with check out) a drawing, do some change, when she login the drawing, AutoCAD crashed with "Fatal Error: ...".
  What should I done to fix it?
  Thank you so much.
Wes
Windows 7 64 bit
AutoCAD 2012 with Vault CAD Addin 2012
Vault Pro 2014
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
Tags (1)
6 REPLIES 6
samuel.seah
in reply to: wesbird
Hi Wes,
Can you check that the AutoCAD Add-In for Vault has been installed for her user profile? You can do so by accessing Windows Program and Features -> Autodesk Vault Client -> Uninstall/Change -> Add/Remove Features. It is not advisable to copy and load the vaac.cuix customization file manually.
Samuel
wesbird
in reply to: samuel.seah
Hi Samuel:
  Thank you for your time.
  Vault CAD Addin has installed because I can check out drawing in AutoCAD.
  This is a typo in last sentense of my post,
  "when she login the drawing, AutoCAD crashed with "Fatal Error: ...". "
  should be
  "when she check in the drawing, AutoCAD crashed with "Fatal Error: ...". "
Wes
JeffPaquette6500
As Samuel suggested, perhaps Vault was installed properly using your Windows profile, but with your co-worker's profile, it was not installed properly.
Try logging into Windows as your co-worker, and installing Vault client.
Or try this:
To restore the Vault ribbon and toolbar, enter CUILOAD and load the "VaAc.cuix" file from the respective locations:
  • For Windows XP - C:\Documents and Settings\ [username] \Application Data\Autodesk\ [product name] \R18.1\ [lang] \Support
  • For Windows 7 and Vista - C:\Users\ [username] \AppData\Roaming\Autodesk\ [product name] \R18.1\ [lang] \Support
Another possible solution can be found here:
http://crackingthevault.typepad.com/crackingthevault/2013/10/vault-ribbon-missing-in-autocad-applica...
Jeff Paquette
Data Management Support Specialist
wesbird
in reply to: JeffPaquette6500
Hi Jeff:
  first thank you for your response.
  In last 2 week, I worked with our IT department to
  1. repair install Vault AutoCAD Addin
  2. re-install Vault AutoCAD Addin
  3. un-install and re-install AutoCAD, Vault Addin
  4. re-image Windows, re-install AutoCAD, Vault Addin
  when I check in drawing in AutoCAD, still got the "FATAL ERROR: ..." error message in the attached file.
  I test with IT administrator account, my admin account, my co-worker working account, all same crash.
  I tried it on 3 others co-worker, same problem. only one even weird:
  if I login Windows as my name, it crash as everybody;
  if my co-worker login Windows as her name, it works fine.
  Please help, I need them to test on all our major client to find what kind of problem will be before production.
Thank you,
Wes
JeffPaquette6500
Wes,
Is this error happening on a particular drawing, or all AutoCAD drawings?
Are you running AutoCAD 2012, and Vault client 2012, all with the latest service pack?
Jeff Paquette
wesbird
Hi Jeff:
  Thank you for your reply.
  This happen on any drawing.
  It works on 3 of 7 machine but not the other 4. All are AutoCAD 2012 but in different vertical product. mine is Map 3D, others are AutoCAD Architecture;
  Vault Server is 2014;
  Client side, Vault client, Office Addin and Outlook Addin are all 2014, AutoCAD Addin is 2012.
  Out IT and I use one of problem computer to troubleshoot.
  yesterday, we install the AutoCAD Architecture 2012 SP2, stil same crash.
  today, when check in, I change the "Visualization Attachment Options" from "Create during check-in" to "Do not create", then it works.
  Now the question is why it crash when create visualization file?
Wes
